Spacelabs - Blease Datum L
by Spacelabs
The Blease Datum L vaporizer provides excellence in output stability across various flow rates and temperatures, over extended periods of use.
Even through the demands of mask inductions with high gas flow and vapor settings, the BleaseDatum meets the clinical challenge to provide the concentration demanded, into the patient circuit.
For a decade, the BleaseDatum has set the standard for long term reliability, performance, stability and value. BleaseDatum, the first vaporizer to be free of routine maintenance requirements, is now backed by a 10-year warranty. The BleaseDatum vaporizers are in use around the world, chosen for drug delivery on Spacelabs Healthcare anesthesia systems, and others.
FORUMSView All (4)
-Raquel
4 years ago
Vaporizer
I need to identify this code number: Blease datum 13062330
-Raquel
5 years ago
datum13063327
can you please tell me which product is this code number: datum 13063327Reply
5
-Bastinious
6 years ago
Service manual for Anesthesia tec 5
Do you have a copy of service manuula for Ohmeda Tec 5Reply
  • Proven output stability over wide range of conditions
  • No required maintenance
  • 10 year warranty
  • Sevoflurane, Isoflurane, Enflurane, Halothane
  • All common mounting systems
  • Key Fill, Screw Fill, Quik Fill
  • More than 60,000 sold globally
  • More surface area for Vaporization
  • Unique ventilation compensation system
  • Accurate in low flow anesthesia
Flow Rate Range0.2 to 15 L/min
Agent Capacity (+/- 25ml) 250ml         Altitude (up to and including): 2440m asl         MRI compatible: up to 1000 gauss line         Output Accuracy         +/- 15% of set volume % or +/- 0.15 vol%         (8% Sevoflurane models +/- 20% of set volume or +/- 0.20 vol%) whichever the greater over the nominal condition ranges
