Sysmex - CA 530
Offering superior capabilities for your low-volume labThe Sysmex® CA-500 Series is comprised of the CA-560 and CA-530 — compact, fully-automated systems featuring immunologic*, coagulation and chromogenic measurements in true random access. These five-parameter coagulation analyzers are designed primarily for use in low-volume laboratories or as a backup instrument to larger Sysmex® instruments.
3Replies9 years ago | CA-530 Hello, What are best PT reagent ,controls and calibrator for CA-530? Thanks LC Reply |
1Reply9 years ago | CA-530 Hello, We are thinking of putting a CA-530 coag analyzer online but not sure if Sysmex still make parts/service. Also,trying to track down operator manual on (pdf). Thanks LCARNES Reply |
- Clotting and chromogenic detection allow for customizable testing
- On-board quality control (QC) package provides reliable patient results
- Scalable menu designed for low-volume labs
- Ease-of-use and low maintenance allow for economical testing
- No cuvette waste facilitates efficient processing
- Random access allows for independent operation
- Bi-directional interface eliminates transcriptional errors
- Minimal consumables required with little operational waste
- Simultaneous analysis can be performed for 5 parameters using 2 different methods of coagulation measurement (clotting and chromogenic). The routine analysis can be interrupted for STAT samples.
Height | 49 cm |
Length | 47 cm |
Weight | 99 lbs |
Width | 54 cm |
