Drucker Diagnostics - 853VES
by Drucker Diagnostics
The 853VES is a medium capacity centrifuge with unmatched performance
The 853VES offers control over almost every aspect of the unit's operation from variable acceleration and deceleration to easy time and speed input. The exclusive Drucker horizontal rotor allows for quick and easy sample loading and complete horizontal separation. An optional Performance Plus horizontal rotor is available providing increased speed up to 5,000 RPM. Save your settings in one of 10 memory locations and recall them at the touch of a button. A wide variety of optional accessories are available to customize your centrifuge.
-Shmowland
2 years ago
Breaker trips after couple seconds
Unit trips internal 4 amp breaker after 2-3 seconds. Any previous experience on this issue? Thanks
[list]              [*] Electronic Timer and Speed Control with Display: Selectable time setting from 0 to 99 minutes, or hold for continuous operation. Control speed from 500 RPM to the maximum rotor speed.            [*]Capacity: Up to twelve 1-10 mL tubes with horizontal rotor, up to twenty 1-15 mL tubes with fixed angle rotor, up to six 50 mL tubes with fixed angle rotor            [*]Memory: Store up to 10 user defined preset configurations            [*]Brushless DC Motor: For smooth and quiet operation with no routine maintenance            [*]Variable acceleration and deceleration: Customize the run from start to finish            [*]Quiet operation and low vibration: Double encased motor assures quiet performance and low out-of-balance vibration            [*]Audible end-of-run indicator: Sounds when the rotor has stopped to inform the operator that a cycle is complete            [*]Positive lid latching: Firm mechanical latching of the lid prevents the escape             [*]Imbalance Detection: If an imbalance is detected, the centrifuge will come to a of debris in case of breakage or an accidentsafe controlled stop            [*]Welded Steel Construction: Provides strength and durability for years of use            [*] Clear shatter proof lid: Allows for safe sample observation and optical calibrations            [*] Regulatory Approvals: ETL Compliant to ANSI/UL standards, CE marked            [/list]
Height9 in
Length 14.75 in
Weight34 lbs
Width12.5 in
[list]    Voltage: 115 (± 10) Volts, 220/230 (± 20) Volts            Frequency: 50/60 Hz    Max. Power Requirements:    - 150 Watts for 115V    - 230 Watts for 230V    Protection Breaker: 4 Amp. Re–settable    Centrifuge Motor: 1/2 H.P. Brushless DC    [/list]
