Pharmacia LKB - LKB Biochrom ULTROSPEC II
by Pharmacia LKB
Spectrometer
Ease of operation is achieved by using a microprocessor to perform most of the repetitive talks usually requiring prolonged operator action. The instrument is capable of performing absorbance, concentration and transmittance measurements on up to five samples plus on reference at wavelengths in the 200 nm to 900 nm range. Ideal for biological samples when using standard 10 mm cuvettes. Pharmacia LKB Biochrom ULTROSPEC II is designed as a simple to use instruments capable of producing rapid measurement of light absorption or transmission. The LKB Biochrom Ultrospec II UV/Vis Spectrophotometer is designed to produce rapid measurements of light absorption or transmission in both the ultra-violet and visible spectra. Capable of performing the absorbance, concentration and transmittance measurements on up to five samples plus one reference, the Ultrospec 4050 features wavelengths ranges from 200nm to 900nm.
6RepliesSat Aug 24 2024 | Software for LKB Ultraspec II Hi there - does anyone know where I can find software to operate the LKB Ultraspec II? Or, a Perkin Elmer Lambda 2??? thankyou sincerely in advance if you can point me in the right direction. Reply |
0RepliesFri Sep 24 2021 | Calibration error 3 Hello, after replacement of the tungsten lamp, the calibration fails at step 3. Does anybody know what this means? It would maybe already help if the user manual was available in total, as the section 5 with error messages is missing in the uploaded pdf file. Thanks a lot for your help.Reply |
0RepliesThu Aug 05 2021 | Pharmacia LKB Pharmacia LKBReply |
| Height | 23 in |
| Length | 14 in |
| Weight | 44 lbs |
| Width | 18 in |
