Hillrom - Totalcare P1900
by Hillrom
1ReplyTue Feb 25 2025 | Moving Bed Move bed to assisted living facility with limited elevator and stairwell access Reply |
1ReplyWed Aug 07 2024 | HiLo foot of bed will not lower Hello, I have a Totalcare P1900 that as of today the foot of the bed will not lower using the hi lo button at the top side rail. The head will lower, but the foot is now at maximum height. Hitting the lower button keys the head lower but the foot stays in place, just like putting the bed in Trendelenberg position. I called support and they had me swap the solenoid for the up and down high low, but this had no effect. He said it it's probably the valve that is stuck and can be removed from the manifold to be cleaned or replaced. How do i remove this valve from the manifold? Is there a way to manually lower the bed? I took bolts off the bracket on the foot of the large hydraulic cylinder for the bottom section, but didn't see how to release it. Any suggestions or copies of the service manual for this bed would be appreciated. We moved my son to a small makeshift bed until we can get this lowered to normal level height out fixed. Thank you! Equipment: Totalcare P1900 Reply |
0RepliesSat Sep 02 2023 | Battery mode switch location? Try'n to help family member. Bed wouldn't lower.... Someone hit CPR. .... after, Bed wouldn't level out . Got cylinder off..... Lowered bed by hand. Plugged in & nothing, it does nothing. Please help if able. Thank you. Equipment: Hillrom - Totalcare P1900 sport Reply |
[list] [*] Critical Care Hospital Bed [*] Controls on the side rails for all positions [*] Both manual and electric controls as well as full chair position [*] Trendelenburg position to facilitate ease of care and add comfort [*] Removable Head and Footboard [*] All four wheels lock from a single pedal on both sides of the bed [*] CPR Release [*] GCI Interface [*] Nurse SideCom & Patient SideCom Controls With Lockout [*] Hands-Free Emergency Trendelenburg Release [*] Hands-Free Emergency CPR Release [*] Recliner Positioning [*] Full Chair & Chair Egress Positioning [*] Bed-Flat Control [*] Flex-A-Foot Retractable Foot Mechanism [*] Fluoroscopy Compatible [*] Automated Underbed Nightlight [*] Drainage Bag Holders [*] IV Pole Storage [/list]
| Bed Type | Electric |
| Patient Weight Capacity | 500 lbs |
