Biomerieux - Mini Vidas
Mini VIDAS is greatly appreciated worldwide for its simplicity, flexibility, reliability and 24/7 availability.
Mini VIDAS processes single sample and batch tests for all types of analysis: serology, immunochemistry, antigen detection. Ten different analytes can be used simultaneously. All enzyme immunoassay reaction stages are performed automatically in minimal space: pipetting, incubating, washing, reading, and results are sent immediately to the integrated printer. miniVIDAS is a compact version of the VIDAS system with a built-in computer, keyboard and printer. Two independent sections each accept six tests and can process up to 12 samples simultaneously. These automated immunoassay tests are reliable and economic. It uses ELFA (Enzyme Linked Fluorescent Assay) technology, has no carryover risks, requires a one-point recalibration once every 14 or 28 days depending on the assay and optimizes the cost per patient for batch or single sample testing. In addition, the menu of available assays is constantly growing.
FORUMSView All (7)
0Replies7 months ago | NT pro BNP alarma R5.6.1 Equipment: Biomerieux - Mini Vidas Reply |
1Reply2 years ago | Error and optical hardware failure Hi, when i start MiniVidas appears one error, Optical Hardware Failure, can any one help how can i fix this error, thanks.Reply |
0Replies3 years ago | Optical Hardware Failure Hi, when i start MiniVidas appears one error, Optical Hardware Failure, can any one help how can i fix this error, thanks.Reply |
- Completely self-contained unit
- Analytical module with 12 test positions / 2 independent 6-test compartments
- Integrated monitor, keyboard and printer
Height | 22.6 in |
Length | 22 in |
Weight | 88 lbs |
Width | 17.7 in |
Voltage: 100-240 VAC Electrical Consumption: 1.5 0.8 A Frequency: 50-60Hz Power: 150 Watts Heat emission: Approximately 512 Btu/h
