Sechrist - 3300E
by Sechrist
Hyperbaric chamber
The Sechrist 3300E and 3600E hyperbaric chambers are equipped with the advanced Electronic Control Module. The Sechrist’s innovative ECM module significantly increases the oxygen conservation and patient comfort during treatment. The Sechrist electronic chambers are offered in two uniquely designed models. Both systems include the complete ECM module to control the compression rates and pressure. The Sechrist 3300E and 3600E automatically switches from an initial high flow nitrogen purge rate system to a lower ventilation flow during the plateau stage of the treatment. Using a lower sustaining purge flow can allow savings of up to 65% of the oxygen that would normally be consumed. The lower sustaining flow also provides the benefit of lower noise levels for the the patient.
| Height | 57.5 in |
| Length | 102.9 in |
| Weight | 2030 lbs |
| Width | 46 in |
Internal Diameter: 32.50 inches Internal Length: 90.00 inches Compatible Patient Stretcher Dimensions: 30.5 inches (77.5 cm) wide by 91.5 inches Supported Patient Weight: 500 pounds
