Berkeley - Synevac GP SYSTEM 20C
by Berkeley
If a high performance vacuum pump is a requirement in your specialty, consider the Synevac Central Vacuum System. The expandable features of this unit make this system the perfect choice especially if you are remodeling or building a new surgical suite. Satellite units are attached to the Central Vacuum Source through a simple system of tubes and wall outlets. Pump noise in the O.R. is eliminated. Only one unit may be operating off the Central Vacuum Source at any given time. You are assured the maximum vacuum level during the entire surgical procedure. The remaining satellite stations are set up and ready to operate once the initial procedure has been completed.
[list] [*] Optimum Performance in an Innovative Design [*] Serves up to Four Surgical Stations [*] Double Pump System achieves maximum vacuum in seconds [/list]
