Laerdal - Suction Unit 4 LCSU 4
by Laerdal
No vacuum tube between the canister and the suction pump is necessary - just click-in-place and go. A clean and efficient solution, a used canister can be replaced quickly with a new one when suctioning is completed. The canister is sealed, with an internal filter. The filter automatically stops suction/flow when the canister is full or the filter becomes saturated if the unit tips onto its side during use. Once wet the filter forms a gel which prevents ingress of fluid into the pump. When extra suction volum is needed, an alternative LCSU 4 version is available. This version has a 800 ml Canister supported by a Wire Stand bracket. The Canister is disposable, it can not be cleaned. The Canister has an internal filter in the lid and mecanical shutoff valve that protects against contamination and overflow. To increase filtration efficiency the Vacuum Tube may be replaced with a High Efficiency Filter Kit. The Kit is used in situations where there is a high risk of cross-contamination. Each version can easily be converted to the other canister option by ordering additional parts.
0RepliesThu Nov 12 2015 | Maintenance Needing a copie of the Service and Maintenance Manual Reply |
[list] [*] One-hand-grip design [*] Click-in-place 300 ml canister, no vacuum tube needed [*] 800 ml canister option when extra volume is needed [*] Disposable canister systems [*] Easy to convert between 300 and 800 ml canister version [*] Internal integrated filter systems for all canisters [*] High efficiency filter kit (for 800 ml solution) [*] HEPA rated bacterial filter [*] Battery level indicator [*] Children vacuum range area (marked in blue) on the control panel [*] Arrows pointing the vacuum directions [*] High density carry bags [*] No-tools-necessary field changeable battery [*] Rechargeable Battery, NiMH 12 volt 1.6 Ah. [*] AC/DC Adapter Charger (100-240 V) [*] External Battery Charger [*] 12V DC Power-cord for connection to vehicle connection [*] Multi languange Directions for Use (19 languages) [*] High flow / High vacuum [/list]
| Height | 26.2 cm 300 ml canister version |
| Length | 18.5 cm |
| Width | 8.12 cm |
[list] [*] 800 ml canister version: 23.6 cm x 19 cm x 23.6 cm (9.3" x 7.5" x 9.3") [*] Battery run time: Approximately 45 minutes (free flow) [*] Air Flow @ Vacuum Inlet: 30 LPM (free flow) typical [/list]
