Ultrasound System
Smart and clear imaging combined with eFLOW and Auto Angle Correct makes this a small and reliable system for any work environment. Thoroughly simple and compact. As a user-friendly diagnostic ultrasound system full of functional and ergonomic features, F37 is ready to be the user's partner. The F37’s simple operational features provide an easy and smooth workflow. The necessary controls for routine examinations are intuitively laid out, with high priority on reducing the examiner's operation steps. Imaging features inherited from higher-class models provide a work environment for concentrated examinations. The F37 delivers outstanding images while maintaining comfort for the patient and the examiner.
Ask a New Question2Replies-TARIK 7 months ago | 7 months agoUser manual Need user manualEquipment: Hitachi ultrasound aloka f37 Reply |
8Replies-Fikyo a year ago | a year agoHITACHI ALOKA F37
I have this Hitachi Aloka F37 ultrasound machine, at boot up it gives to messages on the screen The first one is "there is not a reply from the SbeInstFEFirm(-1) The second one is DPM_STAT TM Out Err:0×01 3E BP:0×40 Does anyone have an idea of how to resolve this problem. Kindly assist
Reply |
2Replies-sametert61 2 years ago | 2 years agooperations panel logs Hello,
THE KEYBOARD ON OUR DEVICE SOMETIMES DOES NOT WORK. THE LIGHTS ARE BLINKING CONSTANTLY, BUT THE KEYBOARD IS NOT RESPONDING.CAN YOU HELP ME? Please
THANKS?Reply |
- The most advanced broadband beam-forming technology combined with high speed image processing that allows for higher definition ultrasound imaging than ever before.
- Provides high quality imaging using an expanded range of harmonic signals. This technology results in excellent image resolution and sensitivity and improved penetration.
- Clearly displays differences in tissues, reducing speckle noise while maintaining the frame rate. It can also display outlines more clearly by selectively emphasizing boundaries.
- The ultrasound beam is transmitted and received in real time and in the multiple directions resulting in a reduction of speckle noise, suppression of artifacts, and improvement of contrast resolution allowing lesions to be clearly observed
- At the touch of a button the B-mode image is instantly optimized to the user’s preference. This technology continually monitors the user’s typical settings to optimally adjust the image when pressed resulting in less manual adjustments and more efficient examinations.
- The new high-efficiency probes are very lightweight and designed to be high in energy conversion to transmit high-quality ultrasound beams without raising the temperature on the probe surface.
- The image quality contributes to reduction of examination time
- Patient-friendly examinations enabled by the small size of the probe
- Basic measurement results can be transferred onto the report
- Unique probe holder for endocavity probes
