Draeger - Fabius Tiro
by Draeger
Designed for your environment.
At its core, the Fabius Tiro anesthesia machine features our powerful and accurate E-vent piston ventilator, which gives you the ability to handle a wide range of acuity levels. Its compact design makes it a natural choice for applications where you need to get the most of the available room without having to compromise on features or flexibility. With a wide array of options to choose from, the Fabius Tiro can be customized to suit your needs and even be upgraded when those needs change.
FORUMSView All (7)
-Jeoamp
4 years ago
DISPLAYS ERROR
Dräger - Fabius Tiro displays error upon turning it on. I was wondering if you could help me with a service manual or a solution.Reply
3
-Luis8a
7 years ago
Number Part PM Kit
Hello, i need help with the Number Part of de Preventive Maintenance Kit for the Dräger Fabius Tiro, can any one send to me?
Number Part and list of spare parts of the preventive maintenance kit.
biomedicoochoa@gmail.com
Thanks!
-Timth
8 years ago
Team Lead
Would like to know OEM lifespan of FabiusTiro Anesthesia machine?
  • Intuitive operation and layout ensures ease of use and a short learning curve
  • Ample illuminated workspace
  • Communication with automated record keeping systems like the Dräger Medical InnovianTM
  • Perioperative Care for enhanced patient throughput
Height53.6 in
GasesAir, Nitrous Oxide, Oxygen
Length 24.7 in
Weight245 lbs trolley mount (cart)
Inspiratory Flow (max)75 L/min in Volume and Pressure Control
Vaporizer TypeVariable-bypass
Vent ModesVCV, PCV, PSV, SIMV-Volume with PSV, Manual/Spontaneous.
Width22.8 in
