Draeger - Fabius Tiro
Designed for your environment.At its core, the Fabius Tiro anesthesia machine features our powerful and accurate E-vent piston ventilator, which gives you the ability to handle a wide range of acuity levels. Its compact design makes it a natural choice for applications where you need to get the most of the available room without having to compromise on features or flexibility. With a wide array of options to choose from, the Fabius Tiro can be customized to suit your needs and even be upgraded when those needs change.
FORUMSView All (7)
2Replies4 years ago | DISPLAYS ERROR Dräger - Fabius Tiro displays error upon turning it on. I was wondering if you could help me with a service manual or a solution.Reply |
3Replies7 years ago | Number Part PM Kit Hello, i need help with the Number Part of de Preventive Maintenance Kit for the Dräger Fabius Tiro, can any one send to me? Number Part and list of spare parts of the preventive maintenance kit. Thanks! Reply |
1Reply8 years ago | Team Lead Would like to know OEM lifespan of FabiusTiro Anesthesia machine? Reply |
- Intuitive operation and layout ensures ease of use and a short learning curve
- Ample illuminated workspace
- Communication with automated record keeping systems like the Dräger Medical InnovianTM
- Perioperative Care for enhanced patient throughput
Height | 53.6 in |
Gases | Air, Nitrous Oxide, Oxygen |
Length | 24.7 in |
Weight | 245 lbs trolley mount (cart) |
Inspiratory Flow (max) | 75 L/min in Volume and Pressure Control |
Vaporizer Type | Variable-bypass |
Vent Modes | VCV, PCV, PSV, SIMV-Volume with PSV, Manual/Spontaneous. |
Width | 22.8 in |
