Draeger - Fabius Tiro M
Developed for military field operationsThe Fabius Tiro M was designed to provide a full-featured anesthesia machine in a compact, easy to assemble package for use in military medical installations in the field. The modular design allows all standard system components to be stored in a single container so that assembly and disassembly of the unit is easily accomplished.
- Easy to Use - The modular design allows all standard system components to be stored in a single container so that assembly and disassembly of the unit is easily accomplished
- Flexible Gas Source - As an alternative in areas where a central gas supply is not available, Fabius® Tiro M can also use a defined oxygen generator
- Electronic Ventilator - Electronically controlled, piston-driven ventilator uses no drive gas, decreasing fresh gas usage overall
- Field Deployable:
- Robust system can withstand transport and continue to provide high-level functionality in field operations
- Simple, modular design allows for full set-up within 15 minutes, without the use of tools
- Entire system packs and ships in one container, ensuring delivery of a complete anesthesia machine to the field
- Easy-to-use interface reduces time required for clinicians to become familiar with the system
Height | 30.16 in |
Length | 30.11 in |
Weight | 75.4 lbs Container basic empty |
Inspiratory Flow (max) | 75 L/min in Volume and Pressure Control |
Vent Modes | Manual / Spontaneous Volume Control (VC) Pressure Control (PC) Pressure Support (PS) Sychronized Volume Controlled Ventilation w/PS (SIMV/PS) |
Width | 30.11 in |
