Sechrist - 3200
by Sechrist
Hyperbaric chamber
The Sechrist 3200 is a pneumatically controlled system, which features a spacious 32 inch inside diameter acrylic cylinder for increased patient mobility and comfort. Important capabilities such as ventilation support and intravenous infusion can also be provided. Transcutaneous and other monitoring is possible via electrical ports and pass-throughs. Additional features include a hyperbaric gurney for easy patient transport, an intercom system for two-way private conversation and an auxiliary audio-input for patient entertainment.
1Reply2 years ago | Internal diameter What is the Internal diameter of a 3200 chamberReply |
0Replies8 years ago | Somebody to fix a sechrist 3200 Hello! Do you know a people to fix a Sechrist 3200 "1997"? Thanks Reply |
0Replies8 years ago | Looking for Sechrist 3200 hyperbaric chamber Pm procedure and replacement parts Greetings!
I'm looking for Looking for Sechrist 3200 hyperbaric chamber Pm procedure and replacement parts. If someone could help, it would be very helpfull to me.
Thanks! Reply |
Height | 57.5 in |
Length | 105.5 in |
Weight | 1992 lbs |
Width | 45.5 in |
Design Temperature Range:50°-100° F (10°-38° C)
Medical Gas Supply Pressure:50.0-70.0 psi (3.5-4.9 kg/cm2,0.3-0.5 MPa)
Internal Diameter: 32.5 in (82.55 cm)
Internal Length: 90.0 in (228.6 cm)
Internal Volume: 43.2 ft3 (1.22 m3)
