ZEISS - 30SL-M
by ZEISS
The Zeiss 30SL-M Slit Lamp has 12.5 X Eye Piece Straight binoculars with .6 .4/ 1.5 2.5 magnification. Also, it comes equipt with Blue and Green contrast filters.
0RepliesSat Mar 08 2025 | LED fixating light The LED fixating light of the Zeiss 30sl/m slit lamp is used with the keratometer attachment to measure K readings. The small BOX on the left of the slit lamp has a cable that goes into the body of the slit lamp. There is a black wire inside this box that has been cut and is causing an open circuit , thus, making the LED not light . Which port inside the box , 1, 2, 3, 4, or 5, should this loose wire be connected in order for the fixating LED to work? Equipment: Zeiss 30sl/m slit lamp Reply |
0RepliesSat Aug 17 2024 | Service manual or installation manual I am looking for the service manual for the Zeiss 30 SL-M slit lampReply |
7RepliesWed Jun 08 2022 | is this website still operatinhm Was looking for information on zeiss 30 sl/m device but site seems deadReply |
