Hitachi Medical Systems - DHF-105 CX
Mobile C-Arm
DHF-105CX series surgical X-ray units for general use with built-in C-arm cable for orthopedic application.
FORUMSView All (10)
0Replies2 months ago | Errors e 36 Which parts issue Equipment: Hattachi dhf 105 cx Reply |
0Replies8 months ago | ERROR 51 this error occurs when the high voltage of the tube is not correct or has a defect, but this error is possible when the actuation plate has a defect in its commutation, it is worth informing that this equipment is very critical in its repair, it is common to have bad contact in the high voltage head of the pipe. Reply |
0Replies9 months ago | Errore 51 hitachi c-arm dhf-105cx l have a problem with hitachi c- arm dhf-105cx whitch issuied errore 51..somebody help me to know the problem place.. thanks for help Reply |
- C-arm Concealed cable, electromagnetic lock switch, manual braking configuration greatly improved operability.
- Equipped 6mA high dose rate pulsed fluoroscopy and low exposure amount feature perspective.
- 5th gear noise clearance and three contrast selection available to more gentle, clear images.
- Continuous fluoroscopy 30 minutes, and the ball head tube temperature display.
- Standard with eight image hold feature.
- Adoption of built-in cables, one-touch electro-magnetic lock, hand brake and wireless footswitch (option) has improved operability
- 6mA high X-ray dose fluoroscopy function and low exposure dose high image quality pulsed fluoroscopy function are incorporated
- Max. tube voltage is as high as 110kV, resulting in widened diagnosing area
- Image adjust function which has preset 3 kinds of Γ curve is built in
- 30min. continuous fluoroscopy is possible and tube head temperature display is available
- 8-channel memory function is incorporated as standard
