Advertisement
Dräger - Vapor 2000/ D Vapor
Manufactured by Dräger
Vapor 2000 is a vaporizer for volatile anesthetic
Dräger D-Vapor®
The D-Vapor® offers the established level of dosage performance under all conceivable circumstances. When the D-Vapor is taken off the anesthesia system, the agent reservoir is hermetically tight and the devices can be transported in any position without prior draining. The 300 ml reservoir capacity allows plenty spare volume for refilling from modern large agent bottles.
As expected the Dräger D-Vapor® is free from re-calibration and overhaul. The light weight of less than 6 kg, a wide range of agent delivery up to 18 Vol % and agent dosage after power failure ensures ergonomic and safe handling. All common mounting systems are available.
Dräger Vapor 2000
The Vapor 2000 is a vaporizer for volatile anesthetic agents with excellent performance. Originally developed for the extreme requirements of mobile army surgical units, these demanding ambient specifications benefit the normal, daily clinical routine in anesthesia.
Moreover this offers clear handling advantages. It is simple to fill and large enough to hold a full bottle of anesthetic agent once the minimum mark has been reached. In addition, it can be turned to the "T-setting" and this does not have to be emptied prior to transport.
QUESTIONS & ANSWERSView All
Answers
-Numair
5 months ago
Vaporizer
Can the steckadapter be removed from an ISO vaporizer and put on a sevo vaporizer Reply
3
Answers
-macone
9 months ago
repair
looking for schematic of Drager vapor 2000, internal and external
thanks you
Answers
-J Scot Mackeil CBET
a year ago
factory PM procedure for vapor 2000
if anyone has an actual copy of the PM procedure for the dragger vapor 2000 vaporizer, could you email me a pdf copy? to jsmackeil@partners.org thanks in advance if you do. J scot Mackeil cbet
DOCUMENTS / MANUALS
PREVENTIVE MAINTENANCEView All
Be the first to submit a preventive maintenance post about this equipment
  1. Medical Vapor family offers is that there is no need to empty contents
  2. no troublesome disposal of half empty agent bottles with the added risk of mix-ups
  3. no risk of breakage
  4. anesthetic agent remains where it is safest -inside a Dräger Medical Vapor.
Concentration Range0.2 to 8 %
Flow Rate Range0.2 to 15 L/min
NEWSView All
!{article.title}
Class 1 Recall: Dräger Evita V500 and Babylog VN500 Ventilators -...
Dräger is recalling the PS500 battery power supply because a software issue causes shorter than expected battery run times.
!{article.title}
Dräger Earns Respiratory Care's Highest Honor for Seventh Straight...
Dräger Earns Respiratory Care's Highest Honor for Seventh Straight Year – AARC Zenith Award
!{article.title}
Dräger Introduces Innovian Anesthesia 4.1 with remote access option
New Mobile Report Viewer capability enables clinicians to securely access data collected by Dräger’s AIMS on Web-connected devices over the healthcare facility’s wireless network
Advertisement
Ask anything about
Advertisement
For questions about using the MedWrench web site:
(866) 989-7057TOLL FREE  •  (770) 692-8371INTERNATIONAL
support@medwrench.com
MedWrench is in association with:
TechNationMedical DealerOR TodayMD Expo
Testimonials  •  Advertising  •  Privacy Policy  •  Terms and Conditions
© 2017 MedWrench, LLC. All Rights Reserved
Advertisement
