Maquet - Flow-i C20
Brings advanced ICU ventilator performance and anesthesia delivery together in one patient-friendly unit.Representing the latest standard in anesthesia, FLOW-i enables clinicians to continuously adapt and improve anesthesia care to match the situation at hand while maintaining stable respiratory conditions. FLOW-i can be used across the widest range of patient groups, including those with acute respiratory demands and pediatric patients. Modular and ergonomic, FLOW-i is a flexible, adaptable and upgradeable system. Ease of use and training contribute to more efficient use of hospital resources. Please note, the product may be pending regulatory approvals to be marketed in your country. Contact your Maquet representative for more information. FLOW-i comes in three models depending on your needs. All models feature a rotatable arm for flexible screen positioning, tiltable screens to allow for maximized screen visibility and vertical and horizontal rails for auxiliary equipment. FLOW-i C20 offers the added storage space of 2-3 optional drawers. One lockable drawer is always included.
FORUMSView All (3)
3Replies3 years ago | Gas analyzer_ AION Platinum Due to not emptying the water trap, in the Maquet Flow-i C20, water return back to gas analyzer module. Is there a way to repair this module or needs to be replaced. Please advise. Reply |
3Replies4 years ago | t61 error hello, i need service manual of Flow-i C20 . it has power switch probably broken . say error T61 power switch . someone can help me? thx in advanceReply |
1Reply8 years ago | Pressure sensor failed Machine is failing the pressure sensor checkout in the preuse check. But all other parameters are passing. There is no leakage and the cassette is also cross checked with another working unit. Please help me to find a solution. Reply |
[list] [*] Set tidal volume is accurately delivered in spite of high abdominal and thoracic pressure, helping to avoid hypoventilation. [*] Fast rise time and high flow rates adapt to varying inspiratory demand in the presence of increasing airway pressure. [*] Sensitive triggering improves synchrony in pediatric patients and those with decreased respiratory drive. [*] Controlled pressure drop during expiration decreases expiratory resistance and work of breathing, in addition to minimizing auto PEEP at higher respiratory rates. [*] Maintains consistent and accurate PEEP levels. [/list]
FDA AlertsView All
Class 1 Recall: FLOW-i Anesthesia Systems - Dislodged Patient...
The firm has received several complaints where patient cassettes, which are the center of gas flow in the system, have come loose.
