Allied Healthcare Products - Gomco 405
The Gomco AC Model 405 is a high-performance general use tabletop aspiratorThe Gomco AC Model 405 is for use in hospitals, clinics, physician’s offices, nursing home facilities and home care. This durable unit meets the need for controlled vacuum regulation up to 635 mm Hg of vacuum with a flow rate of 40 lpm at open flow.The aspirator has a high-impact plastic housing and powerful rotary vane pump, reduced operating noise level, and weighs less than 15 pounds. Each unit comes with either a 1500 ml disposable canister or a 1200 ml reusable glass bottle, a suction tubing kit, and three hydrophobic bacteria filters.
SERVICE COMPANIESView All Aspirator Companies
[list] [*] Powerful rotary vane pump excels at pharyngeal and nasopharyngeal procedures [*] Compact the 405 takes up less than one square foot of space [*] Self-contained unit provides protection against pump and gauge contamination, and allows for easy clean-up [*] Low maintenance requirements [*] Durable high-impact plastic case [*] Disposable hydrophobic bacteria filter eliminates pump flooding and helps prevent fluid and aerosol contamination [/list]
Height | 9.5 in |
Length | 10 in |
Weight | 14.5 lbs |
Width | 12.5 in |
