STERIS - Caviwave Pro
by STERIS
Ultrasonic Cleaner
The powerful patented CaviClean dual frequency technology provides powerful micromechanical scrubbing frequency of 132kHz which more than triples the commonly used 40kHz. The micromechanical scrubbing action efficiently cleans both hard to reach internal passages as well as the heavily soiled external surfaces. Ultrasonic cleaning at higher frequencies creates an abundance of minute vacuum bubbles which allow for cleaning to occur. These bubbles implode on and inside surgical device* surfaces in a process defined as cavitation. This micromechanical scrubbing action is able to reach small crevices, irregular surfaces, and internal passages to ensure proper and consistent cleaning.
1ReplyFri Oct 07 2022 | Caviwave Pro Getting a code sump too long to fillReply |
1ReplyTue Jan 26 2021 | Water Usage What is flow rate and required volume for DI water rinse cycle?Reply |
3RepliesTue Oct 29 2019 | Maintenance Hello, Looking to find out about the maintenance on this or maintenance section of service manual.Reply |
