Canon - CXDI-701C Wireless
Digital Detector
Canon's New CXDI-701C Wireless, cassette-size digital radiography system gives you more freedom for easy retrofit and upgrading options. The CXDI-701C Wireless system ensures best performance n workflow, sensitivity, image quality and versatility.
FORUMSView All (7)
2Replies4 months ago | Canon software Please I need software for canon CXDI 701c Thanks Reply |
0Repliesa year ago | Service Manual is the service manual for this product available? Equipment: Canon - CXDI-701C Wireless Reply |
0Replies2 years ago | working issue CXDI-701C Wireless, I read all its manuals and also install perfectly but some its reduce the result accuracy I want to reason behind that.Reply |
- Greater sensitivity
- Improved Image Quality
- Optimized workflow
- Control Software NE
- Retro Fits to any Solution
- Easy upgrade
- Non Generator Connection mode
- Graphical User Interface support with small sized PC
- Improved water resistance
- Large imaging area of 35cmx43cm
- High resolution with 125 micron pixel pitch
- High sensitivity with CsI Scintillator
- Approximately 140 images with a fully charged battery
- Detection possible with just 2 devices
- Up to four detectors can be used in one room, offering you maximum flexibility to accommodate the required workflow in your institute.
- Pixel pitch: 125 µm
- Imaging area: 35 cm x 43 cm
- Sensor dimensions: 38.4 cm x 46.0 cm x 1.5 cm
- Weight: 3.3 kg
- Scintillator: Cesium Iodide Scintillator
- Wireless: Standard IEEE 802.11n (2.4 & 5GHz dual band)
- Preview time: Approx 3 sec.
- Cycle Time: Approx 9 sec.
- Battery Performance: Approx 140 images
- Charging time: Less than 3 hours
