Aloka - SSD-1700 Dynaview II
ALOKA SSD-1700 Dynaview II Color Doppler is one of the premier ultrasound scanner.
Aloka introduces SSD-1700, a color-flow ultrasound scanner with an option available to support digital management of ultrasound images. The scanner employs a similar imaging architecture to Aloka's existing SSD-2000 scanner, but users can add a data management subsystem (DMS) for functions such as image processing and archiving.
FORUMSView All (6)
1Reply5 years ago | ALOKA SSD 1700 Where does an Aloka SSD 1700 stores its files? Could you extract them to a normal hard drive? And get them on a MacBook? USER MANUAL where to find?! Reply |
1Reply8 years ago | regarding above machine Aloka SSD-1700 Dynaview II We have above machine our problem is machine is booting and finally triangle screen is not appering. all other functions are working fine. there is no problem with proble.and there is no problem with 5 volts supply. I am suspecting behing the machine there is a power supply unit in that all de voltages we can measure but + 15 volts is not showing and -15 volts are also not showing. kindly support me regaring this matter. Reply |
0Replies8 years ago | Aloka SSD 1700 boot up problem and service manual Dear all, Does anyone have the service manual for Aloka SSD 1700? Or if anyone could help with booting up the machine. My machine only show message "System set-up in progress/ System 6.1" and never pass that process. Thank you in advance for your help. My email: sophannahor27@gmail.com Phanna Reply |
