Smith and Nephew - Dyonics 25
Fluid Management SystemThe DYONICS 25 Pump is specifically designed to maintain a clear image while providing the surgeon with very accurate in-joint pressures.
0Replies8 years ago | biomed test key i need biomed test key please can you help me. thanks Reply |
5Replies9 years ago | Dyonics 25 Fluid management system Who needs the OPS/SM manual and Biomed test key for the for the affor mentioned Dyonics 25 fluid management system Reply |
[list] Flow rates up to 2.5 lpm Maintains stable pressure in the joint and also maintains clear field of view. Easy to set up and use Simply insert the tubing cassette, select the cannula size and press START. Multiple tube set options A variety of tubing options are available, including day tubing, which enables you to select the most cost-effective solution for your facility. LEVELERT II Fluid Level Sensor [*] Durable and easy to use. [*] Battery operated unit with auto power off. [*] Provides audible and visual alarms when fluid bags are running low Wireless Remote Control Provides full control of all pump inflow and outflow functions from anywhere within the OR. [/list]
