Nuvo - VistOR SP
by Nuvo
VistOR SP Spot Light for Operating Rooms
The VistOR SP Model features camera-grade iris diaphragms for precise adjustment of the spot size and intensity control. To accommodate all the areas of use, this light can be configured to be Ceiling-, Wall- and Track-Mounted as well as being available as a Freestanding Mobile Unit.            The VistOR Spot Lights feature the unique capability of providing a small, tightly-focused pattern that can be enlarged to provide a perfectly homogenous 16-inch pattern of light. The defined nature of the spot makes these lights ideally suited to applications in cosmetic, ENT and trauma surgery.
[list]      Features of the VistOR SP Spot Light      [*]Continuously adjustable spot size from 3-inches to 16-inches      [*]Light Intensity of 21,500 Lux with a color temperature of 3,500°K      [*]Smooth, easy-to-position, drift-free articulating arms      [*]Removable, sterilizable handle that will also accept most brands of disposable gloves      [*]Long lasting quartz halogen bulb            Mounting Options      [*]The VistOR range of lights have been designed to offer the most comprehensive combination of mounting options to meet the needs of virtually any application. The interchangeability of the light head allows you to custom configure the light to suit your exact needs. Whether you’re looking for a Ceiling, Track, Wall or Mobile Mount the VistOR light is your answer.      [/list]
Reflector Diameter: 2 inch Lens      Lux Output: 21,500      Pattern Size (in): 3 inches to 16 inches      CRI: >91      Depth of Field (in): Infinite      Color Temperature: 3,500°K      Light Source: Quartz Halogen      Bulb Life: 500 hours      Bulb Change: Bulb can be changed in minutes requiring just a Philips screwdriver      Sterile Handle: Detachable, Sterilizable Handle      Head Light Turret: N/A      Electrical Output: 120v 50/60 Hz; 220v 50/60 Hz; 230-240v 50/60 Hz      Bulb Voltage/Wattage: 20VAC/150W      Intensity Levels: Variable      Mounting Options: Ceiling Mount, Wall Mount, Mobile and Chuttle Track      Agency Approvals: UL 2601; CUL; CE Mark
