Nuvo - VistOR SPF Spot Light
NUVO VistOR SPF Spot LightThe VistOR Spot Lights feature the unique capability of providing a small, tightly-focused pattern that can be enlarged to provide a perfectly homogenous 16-inch pattern of light. The defined nature of the spot makes these lights ideally suited to applications in cosmetic, ENT and trauma surgery. The VistOR SPF Model offers all the features of the SP with the added dimension of a separate integrated light source to power a head-mounted Fiber Optic Head light as well as provide a light source for many of the current brands of cameras.
[list] Features of the VistOR SPF Spot Light: [*] Fiber Optic Light Source [*] 4-Position Turret for easy connection to ACMI, Wolf, Olympus and Storz light systems and most brands of headlight [*] Dual power switches allow the Spot Light and the Fiber Optic Light to be used independently or together [*] Separate long-lasting quartz halogen bulbs for each light source Application [*] The VistOR SPF Model offers all the features of the SP with the added dimension of a separate integrated light source to power a head-mounted Fiber Optic Head light as well as provide a light source for many of the current brands of cameras. Mounting Options: [*] The VistOR range of lights have been designed to offer the most comprehensive combination of mounting options to meet the needs of virtually any application. The interchangeability of the light head allows you to custom configure the light to suit your exact needs. Whether you’re looking for a Ceiling, Track, Wall or Mobile Mount the VistOR light is your answer. [/list]
Reflector Diameter: 2 inch Lens Lux Output: 21,500 Pattern Size (in): 3 inches to 16 inches CRI: >91 Depth of Field (in): Infinite Color Temperature: 3,500°K Light Source: Quartz Halogen Bulb Life: 1,000 hours Bulb Change: Bulb can be changed in minutes requiring just a Philips screwdriver Sterile Handle/b]: Detachable, Sterilizable Handle Head Light Turret: 4 Position Turret Electrical Output: 120v 50/60 Hz; 220v 50/60 Hz; 230-240v 50/60 Hz Bulb Voltage/Wattage: 20VAC/150W Intensity Levels: Variable Mounting Options: Ceiling Mount, Wall Mount, Mobile and Chuttle Track Agency Approvals: UL 2601; CUL; CE Mark
