Canon - CXDI-55G
by Canon
Digital Detector
The Canon CXDI-55G Multipurpose Portable Digital Radiography System offers exceptional digital radiographic imagery, large area detection, and a detachable cable for time-effective transport and simple installation, in addition to the compact body. Equipped with a large 14 inch x 17 inch (35 cm x 43 cm) imaging area, the CXDI-55G Digital Radiography System can accommodate a wide variety of DR. The generous size is suitable for radiographic applications including skull, spine, chest, abdomen, and extremity examinations.
2Replies6 years ago | Need refurbishment I need a vendor who can refurb or exchange 9 year old detectors. Qty. 3. Reply |
1Reply6 years ago | Canon CXDI-55G refurbishment / repair We have three 55G detectors used in our Vertex Rad rooms. Does anyone know of a third party repair source? Reply |
0Replies7 years ago | CXDI-55G Self Diagnosis Fails Test E-1 The detector works well with normal use and it passes the performance test. When performing QA, the self diagnosis test E-1 fails (0 x 00000008) and tests B-1, C, and D pass successfully. If we perform a calibration, the self-diagnosis will pass all tests but the radiology QA tech states that this should be performed annually and not on every routine QA. [Our software version is 1.40.2] Any thoughts or suggestions? Do we need a software upgrade? Reply |
Thin and lightweight body
Detachable Cable
Power Box
Immediate Results
LANMIX MLT(S) Image Processing
Enhanced Productivity and Program Imaging Mode
Canon's LANMIT® Technology
Height | 15 mm |
Length | 481 mm |
Weight | 7.5 lbs |
Width | 48 mm |
