GEMSS - Spinel 12HD
by GEMSS
Mobile C-Arm
The SPINEL 12HD features a 15.3” Dynamic Flat Panel Detector which produces the highest quality images possible with no distortion and minimized exposure to unnecessary radiation. The sleek modern design and creative operational controls allow the SPINEL 12HD to move easily in confined spaces for increased hospital efficiency and patient comfort. With advanced technology and optimized image processing, the SPINEL 12HD is the preeminent resource in every surgical setting, whether general surgery, orthopedic, neurosurgery, gynecology, angiography, vascular, anesthesiology, radiation oncology, interventional radiology or ERCP.
-Abdullah33
Tue Jan 05 2016
Abdullah33
error code 1003 and 1004
  • User Focused Control Panel
  • The large 10.4” touch screen control panel rotates a full 270° to allow complete control in any position without moving the cart. Quick Navigation UI system is a sophisticated and intuitive design that is easy to learn and operate.
  • CXView 3
  • The proprietary CXView 3 software features a user-friendly interface and improves workflow efficiency. Register patients easily with functions such as Merge, Match and Split. Transfer images between two servers or more. Export images in a variety of formats. All functions are fully DICOM 3 compatible and integrate seamlessly with PACS.
  • Designed for Optimum Flexibility
  • The SPINEL 12HD is specifically designed to be simple and intuitive to operate as well as compact and space-saving. It not only optimizes surgical workflow, but enhances the value of limited arenas.
  • Premium Monitor Cart
  • The Premium Monitor Cart is simple and compact yet functional and mobile. Two 19” LCD High-Resolution monitors with motorized elevation easily adapt to each user’s viewing preference and fold for complete mobility. Impact sensing actuators eliminate the risk of damage.
  • Mirrored Storage Raid
  • Mirrored storage avoids any loss of data in the event of a system failure by saving data to a Redundant Array of Independent Disks and increases stability in the OR.
  • Back-Up Fluoroscopy
  • The ability to switch monitor inputs for emergency DIS image support, in the event of system error, provides Back-Up Fluoroscopy and a flexible response to any circumstance.
  • Third Monitor
  • In order to share real-time video with an assistant medical team, a Third Monitor can be connected via DVI terminal with no loss of image quality.
  • Convenience
  • Single power input
  • Sub-handles
  • Motorized monitor up/down
  • 3rd monitor
  • Lowering Dosage
  • Continuous mode (Low dose)
  • Pulse mode (Half & Quarter dose)
  • Dose report
  • Multi leaf collimator & virtual collimator
  • Laser guide
  • Detachable grid
  • Pulse mode
  • High Resolution B/W 19LCD Medical Grade Monitors
  • Back-up fluoro -Heating indicator
  • RAID 1
  • Easy Archiving And Documentation
  • DICOM 3.0 -CD/DVD Burner
  • DICOM Paper print support
  • USB Port
