IRadimed - MRidium 3860+
The World’s Only 'Non–Magnetic' IV Infusion PumpThe MRidium™ 3860+ and its ability to infuse medications in the MRI room extends the same quality of bedside care experienced in other areas of the hospital right into the MRI suite. The MRidium™ 3860+ helps replace 'work around' solutions like running long lines from conventional pumps through a sealed MRI door or wave guide. The 'work around' practice of placing long lines from outside the MRI control room may lead to questionable flow rates and alarm delays due to line occlusions, increased infection rates and costly medication waste. Cleared by the FDA for use with up to 3T MR scanners the MRidium™ MRI Infusion System is designed for the continuous delivery of fluids and medications for your patients within the MRI environment. The MRidium™ 3860+ allows clinicians to safely and reliably run both volumetric and syringe dosed infusions by way of Syringe, Bags, and Bottles. The Wireless Remote eliminates the delays caused by stopping a crucial scan just to review, titrate or deliver a bolus. The MRidium™ 3865 is a valuable tool to help decrease the amount of time a patient spends in the MR scanner which may lead to improved throughput and care. The MRidium™ 3860+ 'Dose Error Reduction System' provides a comprehensive safety solution at the patients 'point of care'. Designed to reduce infusion errors, the DERS custom drug library enhances the quality of patient care, maintains compliance with National Safety Standards and provides potential cost savings. Clinically approved and validated by your pharmacy, the DERS custom drug library with its pre-programmed hard and soft 'SafeGuards' helps prevent infusion errors by defining clinically acceptable dosing ranges. MRidium™ MRI Infusion System provides the 'Safety, Accuracy and Reliability' you expect for patient's requiring continuous infusion's within the MRI environment.
FORUMSView All (5)
1Reply3 years ago | Operation How to add volume? Reply |
1Reply4 years ago | service manual what is error 101, I believe it to be a simple error however I cannot find the service manual anywhere to explain the error codes.Reply |
2Replies4 years ago | error check Door A when push start key I load theIV set tubing for MRI infusion pump 3860 and set an ifusion ,I pushed start key the it gave alarm check door A,and everything lokk normak can you please advice . thanksReply |
[list] [*] World’s ‘Only’ Non–Magnetic IV Infusion Pump [*] Placement up to the 10,000 Gauss Line [*] Intuitive Smart IV Pump technology reduces field errors [*] Expandable to a second infusion channel [*] Masimo™ SpO2 Patient Monitoring [*] Large 10-Numeric Keypad – Quick Programming [*] Infusion Range – 0.1 to 1400 mL/Hr [*] Over 12–Hour Battery at 125mL/Hr [*] Adjustable KVO Rate [*] Upstream / Downstream Occlusion Detection [*] Air-in-Line Detection [*] Delivery via Syringe, Bag or Bottle [/list]
Volume to be Infused | 0.1 to 999 ml |
Flow Rate Range | 0.1 to 99.9 ml/h |
KVO Rate | 1 to 5 ml/hr |
Power Consumption : 12 Hours at ? 125 mL/hr Rate Battery Charge Time: 200 charge/discharge cycles MRI Magnet Compatibility: 0.2 to 3.0 Tesla MRI Systems
