Leica Biosystems - CV5030
by Leica Biosystems
Slide strainer
The Leica CV5030 fully automated glass coverslipper produces slides with superior optical quality for reliable long-term storage. Its capability of handling a large variety of slide racks from different suppliers makes the Leica CV5030 very flexible. All common mounting media, including xylene-free varieties, can be used. The operator can choose wet or dry coverslipping. The CV5030’s performance achieves three goals: Highly consistent and reliable coverslipping quality, full adaptation to individual laboratory set-ups, integration into staining/coverslipping workstations to form a fully automated walk-away system.
FORUMSView All (4)
-MedWrench Crystalyn
Wed Jun 02 2021
Leica CV5030 Coverslipper
Leica CV5030 CoverslipperReply
-Ross
Wed Jan 24 2018
Leica CV5030 coverslipper sucking air
I am looking for a service manual, or information. A customer has a Leica CV5030 that has been observed drawing xylene and air up the dispense tube, back into the mountant bottle. I am assuming that either a solenoid(s) has stuck, causing it to be in a "degas" mode when the customer is trying to prime it or dispense.Reply
-Ross
Thu Jan 11 2018
Note to administrators: This is actually a coverslipper, not a slide stainer.Reply
VIDEOS
  • True walk-away operation  - Can be used stand-alone or interfaced with the Leica ST5010 or ST5020 Stainers for true walk-away operation.
  • 400 coverslips at a rate -Coverslips at a rate of 400 slides per hour using standard microscope slides and glass coverslips of different sizes to increase productivity and efficiency in the lab.
  • Open system design - Through its open system design, a broad range of mountants can be used for the highest flexibility.
  • Added flexibility - The CV5030 can be used for different purposes at the same time, e.g. for histology and cytology for added flexibility.
  • Fume extraction system -  The integrated fume extraction system with activated charcoal filter, produces lower concentrations of xylene or xylene substitute in the air, reducing exposure to hazardous fumes for laboratory personnel.
Height550 mm
Length 600 mm
Weight57 kg
Width420 mm
