Lumenis - 1041S, 1055S, 1081S
by Lumenis
The 40 watt 1041S model, 55 watt 1055S model and the 80 watt 1080S model laser systems feature a precise and consistent control of char-free incision and ablation. The high energy pulse mode characteristics of each model provide unique high frequency sequencing that automatically delivers the optimal output for char-free tissue effects at high and low power settings.
0Replies3 years ago | Alarm no ignition on display Hello, I have an alarm no ignition on display.how to clear this alarm .What part need replacement? Reply |
0Replies5 years ago | settings and applications Just need to review the applicable settings for types of procedures. Reply |
0Replies6 years ago | how can I clears a p03 code What is a p03 codeReply |
[list] [*] High utilization in every specialty [*] SurgiTouch compatible for char-free, layer-by-layer tissue ablation [*] Unique periscope design [*] Weightless, spring-balanced arm with a 79” reach [*] Motorized height adjustment [*] Sleek design [*] Small footprint [*] Soft-touch control panel and user prompts [*] Programmable memory protocols [*] Large, brightly-lit display [*] Second display on periscope for improved visibility from operating field [*] User-friendly menus in most major languages [*] Adjustable bright 5mW He-Ne aiming beam with continuous, “blinking” and “off-at-lasing” modes [/list]
Laser Type | C02 |
Height | 81 in Fully raised. Fully lowered-70 |
Length | 21 in |
Weight | 290 lbs |
Wavelength | 10600 nm |
Width | 15 in |
SuperPulse Average Power: 0.5 to 17W / 0.5 to 20W / 0.5 to 20W SharPulse Average Power: 5 to 40W / 5 to 50W / 5 to 55W Pulse Width: 770usec (SharPulse) Pulse Energy: 150mJ / 200mJ / 250mJ (SharPulse) Peak Pulse Power: 430W / 800W / 430W (SuperPulse); 200W / 250W / 300W (SharPulse) Pulse Repetition: 5 to 20Hz / 5 to 50Hz / 5 to 40Hz Aiming Beam: 5mW red HeNe, adjustable intensity while lasing Beam Delivery: Articulated arm, 200cm (79") reach, 200° periscope rotation Controls: Soft touch panel, footswitch Timed Exposure: On time (CW & SharPulse), 0.01 to 1.0 second On time (SuperPulse), 0.05 to 1.0 second Repeat Delay: Off time, 0.01 to 1.0 second Memory Settings: 100 user-defined Cooling: Self-contained, closed cycle
