Sony - UP990AD
by Sony
Black & White Hybrid Graphic Printer. Prints film and paper
The UP-991AD is a black-and-white hybrid printer that supports both analog and digital signals. UP-991AD offers “PRINT, STORE and GO” capabilities with Sony’s IMAGEPORT™ interface. This allows users to either print image store them on a USB drive and transfer them to a laptop. This dual compatibility is especially critical as imaging systems make the transition from analog to digital technology. The UP-991AD can also use the blue thermal media which produces high quality film-like transparencies. The UP-991AD is the ideal choice for medical black and white analog and digital applications such as ultrasound, mobile c-arm, and cardiac cath lab.
[list]        [*]Excellent print quality and contrast        [*]Front panel LCD display for easy operation        [*]Multiple images per sheet (two, four, six)        [*]Fully automatic cutter        [*]Compact design for easy integration into cart based imaging systems        [*]Worldwide power supply and video signal compatibility        [*]Analog video and digital USB 2.0 interfaces        [*]Unique built-in digital capture enables you to store images on a connected USB drive        [*]Sony’s IMAGEPORT™ interface is now incorporated into the UP-991AD        [*]Fast print speed - approximately 8 seconds        [*]Optional blue transparency film (UPT210BL)        [/list]
Connector: Analog, Digital        Dimensions:12.4 x 5.2 x 12.0 inches        Gradation: 256 gradations of gray scale        Interface: Analog: USB        Digital: Video        Power Requirements: 100 to 240V        [*] 50/60 Hz        [*] 1.3 to 2.4A        Print Media: 210mm width roll        Print Size: 10.5 x 7.87 inches (Digital/MAX)        Print Speed: Approx. 8 second (Std mode)        Printer Driver Software: Windows XP 32/64 bit Vista 32/64 bit Windows 7 32/64 bit Windows 8 32/64 bit        Printing Method: Black & White Hybrid Graphic Printer. (Prints film and paper)        Resolution: 325 dpi        Safety Compliance: UL60601-1 Listed        [*]CSA C22.2 No. 601.1 GS        [*]GM UL1950 Listed        [*]CSA C22.2 No.950        Thermal Head: 325 dpi        Type:Black White Printer        Weight: Approx. 17 lb. 10 oz.
