Lumenis - NovaPulse
Quick and easy-to-use method
The NovaPulse CO2 laser provides a quick and easy-to-use method for physicians seeking to expand their practice capabilities. It combines the advantages of laser precision with a familiar, scalpel-like feel. The flexible fiber delivery system, utilizing patented hollow waveguide technology, allows the surgeon to effortlessly access difficult-to-reach treatment sites and cut, ablate, or vaporize the tissue, as directed. Surgeons experience quick procedure time, precise control, and an expanded array of office-based procedures, while patients experience shorter recovery time and minimal post-operative discomfort, allowing them to resume their normal activities earlier than with conventional surgery.
FORUMSView All (10)
0Replies9 days ago | WHAT # WATT TO TEST? HELLO, I JUST RECENTLY PULLED THE LASER OUT TO USE AND I WAS WONDERING IF ANYONE KNEW WHAT # WATTS YOU SET IT ON FOR THAT INITIAL TEST THAT YOU RUN BEFORE USING IT..?? I HAVE FORGOTTEN.. THANKS FOR YOUR TIME - BRETT Reply |
0Replies2 years ago | Pulse alive/ keep alive values Does anyone know where to find the pulse alive and keep alive values? I have replaced my tube and rf board and need to calibrate everything.Reply |
1Reply3 years ago | Error code 82 The manual suggests that there is a disconnect somewhere between the foot press and shutter. Anyone work past this issue? We were helpfully told to "ensure the press was used firmly"...Reply |
- Ideal for a wide range of procedures
- Flexible fiber delivery with patented FiberLase technology
- Effortless access to treatment sites
- Variety of accessories to help maximize efficacy
- Large selection of handpieces and changeable tips
- Lightweight and transportable
- Easy to maintain
- Reduced need for anesthesia and sutures
- Minimal edema and scarring
- Lessened post-operative discomfort
- Quicker recovery time
Laser Type | C02 |
Height | 54 in |
Length | 14 in |
Weight | 46 lbs |
Wavelength | 10600 nm |
Width | 14 in |
SuperPulse Average Power: 2 to 10W (LX-20SP only)
Pulse width: < 800µsec
Pulse Repetition: 2 to 20Hz
Beam Delivery: Flexible hollow fiber (1 or 1.5 meters)
Timed Exposure: On time (CW & SuperPulse), 5 to 500msec
