Draeger - Permox Silent Care
Permox SilentCare. The oxygen concentratorPermox SilentCare, the oxygen concentrator.
FORUMSView All (7)
2Replies8 months ago | Draeger - Permox Silent Care - Tech Help Please Hello, I have a Draeger Permox Silent Care with the following symptoms:- - If switched on with airflow restricted (4Lpm for example), then it triggers an immediate alarm mode and shuts down the compressor. - If switched on with airflow unrestricted (regulator fully opened) it runs just fine and produces oxygen. If left to run, after 5 minutes you get a 3-beep alarm, but it continues to run. - One it is running unrestricted, if the airflow is restricted (to 4Lpm for example), then after a while it will go into a single continuous alarm and shut down the compressor. - I have checked all the pipes, no kinks or snags found, and with the regulator fully open it easily exceeds the flow measurable by the flow meter. - Filters are all clear. - Compressor runs nicely Can anybody please advise on what may be wrong? I notice there is an RS232 port and also a header pin block on the PCB. Can I use these to aid diagnostics? Is there ANY technical or service documentation available apart from the standard use manual? I am located in Hampshire U.K.. Are there any service places nearby? Many thanks for any help or advice. Reply |
1Reply3 years ago | Blinks red light Why does my draeger permox blinks red light with a soundReply |
1Reply4 years ago | Requesting for a manual I am not sure of what to do with red blinking light on my oxygen concentrator- drager permox silent care. Please guide.Reply |
[list] [*] Adjustable flow of oxygen from 0 to 5 L / min [*] The "self-test" - the device after switching performance test carried out for maximum security [*]The device gone through only 80 hours [*]A mobile device with a handle for transporting [*]Power consumption 350W [/list]
Height | 640 mm |
Length | 415 mm |
Weight | 24 kg |
Width | 400 mm |
Flow: 0.5 to 6 L/min Sound pressure level: < 45 dB (A) Mean outlet pressure: 700 mbar
