Hillrom - ClinActiv Plus
Next generation of pressure care management with I-mmersion™ Therapy and Microclimate Management for enhanced protection against skin breakdownThe ClinActiv MCM mattress replacement system from Hill-Rom helps to prevent and treat pressure ulcers in low to very high risk adult patients by providing either alternating or continuous low pressure redistribution.
The patented MCM system also helps to manage the patient microclimate and reduces the risk of tissue breakdown as a result of excessive heat and/or moisture.
Choose between Continuous Low Pressure (CLP) or Alternating Low Pressure (ALP) therapy. The Hill-Rom ClinActiv MCM provides real I-mmersion therapy in both modes to achieve and maintain the lowest possible interface pressures.
0Replies7 years ago | Clinactiv hill rom Is a user manual available? Reply |
0Replies8 years ago | Use manual required Please would you send a user manual for a ClinActiv Plus Pressure redistributing therapy system by email to: jonathan.mason@royalberkshire.nhs.uk. Thanks If you cannot supply it please let me know. Kind Regards Jonathan Reply |
- Five individual low-pressure zones, including a dedicated heel zone
- Real-time pressure adjustment controlled by the internal I-mmersion sensor adjusts internal cushion pressures instantly according to patient size, shape, weight or position
- Flexibility in choosing between continuous or alternating low-pressure therapy modes
- Continuous Micro-climate Management limits the effects of temperature and moisture build-up
- Dedicated heel zone with ultra-low pressure for optimal protection of the vulnerable heel area, and with enhanced lower-leg support
- One touch P-MAX feature provides fast inflation to for easier patient re-positioning and transfer
- Patient Egress Alarm informs nursing staff of any undesired patient egress from the bed
Height | 18 cm |
Length | 203 cm |
Weight | 13.9 kg |
Width | 92 cm |
Control Unit Dimensions (cm): 31 L x 22 W x 28 H
Control Unit Weight: 4.6 kg
