Canon - RadPRO Mobile 40kW
by Canon
RadPRO Mobile 40kW Digital X-ray System
Equipped with a choice of digital flat panel detectors from Canon, the RadPRO Mobile 40kW Digital X-ray System can improve workflow, throughput, and patient care. Fast processing times make it easy to capture high-quality diagnostic images for routine diagnosis or challenging trauma while adding flexibility in patient positioning and the ability to manage or manipulate images at bedside. No more film and chemistry or carrying cassettes to a CR reader; the RadPRO Mobile 40kW Digital X-ray System offers immediate improvements in bedside imaging: from fast turnaround times and outstanding diagnostic image quality.
FORUMSView All (10)
-koelecbadu_3319
Mon May 25 2026
Service manual
Can anyone please help me me with the service manual or schematic diagram for this machine.
Equipment: Canon - RadPRO Mobile 40kW
-koelecbadu_3319
Mon May 25 2026
Service manual
-jakerman22
Thu Jun 15 2023
End of support date
Would anyone know what the end of support date is for the RadPro? Is it 10 years from install?
Canon Flat Panel Detectors
  • The RadPRO Mobile 40kW Digital X-ray System is compatible with the Canon portable and wireless digital radiography detectors. Depending on your organization's needs, each flat panel detector series has either a Gadolinium Oxysulfide or Cesium Iodide scintillator, helping to produce high resolution images that may be previewed within 3-5 seconds.
Single or Dual Panel Solution
  • Single detector and dual panel detector configurations are available.
Mobile Radiography Room
  • Rather than bring the patient to the radiography room, you can bring the radiography room to the patient with this mobile solution. Patients with limited mobility, need assistance at bedside, or in wheelchairs can easily be imaged.
  • For added technologist's convenience, 17" inch touch-screen with integrated generator controls allows the technologist to simply select the study being performed and automatically program the generator to the correct technique. With storage areas for all that a technologist needs during a mobile examination, the RadPRO Mobile 40kW Digital X-ray System is an invaluable resource for the technologist.
Maneuvering and Positioning
  • With a mere press of the handle, large 17 inch wheels that are powered by 2 independent drive motors easily tackles typical facility obstacles. With power-assisted pressure sensitive steering, the RadPRO Mobile 40kW Digital X-ray System is simple to control and drive while minimizing the amount of force required by the technologist. The telescoping tube arm provides 6 additional inches in length to provide flexible positioning management at a patient's bedside. Equipped with precision positioning buttons, a technologist can easily adjust the mobile unit from the handles of the tube arm if needed.
Generator/Power
  • The high frequency generator provides up to 150kVp, 500mA, and 500mAs which, when paired with the standard 300KHU x-ray tube, is powerful enough to shoot through most patients, including bariatric. With 2 battery systems, the RadPRO Mobile 40kW Digital X-ray System provides independent power for exposure control and the drive system reducing power drain and allowing for increased productivity.
Weight1210 lbs
Generator        kW Rating: 40 kW        kVp Range: 40 to 150 kVp        mA Range : 10 - 500 mA Selectable        Number of mA Stations : 18        Exposure Time Range: 0.001 - 10 sec.        mAs Range: 0.1 - 500 mAs        Generator Integration :Yes, 3 PT technique        Anatomical Programs : 500+ Anatomical settings        Line Requirements: Single Phase Line Regulation from 100 - 240 Vac (+/-10%)                X-Ray Tube        Anode Heat Capacity :300 kHu        Focal Spot : 0.6 / 1.2 mm        Target Angle: 12º (Optional 16º)        Tube Rotation : "X" Axis +/- 155°        Tube Rotation: "Z" Axis 90°        Tube Travel - Vertical: 57 inches (145 cm)        Tube Travel - Horizontal: 23.6 inches (60 cm)                Tube Arm        Counterbalanced Tube Arm: Yes        Collimator: Manual        Lock Release Points: 5        Tube Arm Reach: 48.8 inches (124 cm)        Column Rotation : +/- 270°        Maximum Focal Distance to Floor: 79.7 inches (202.5 cm)        Minimum Focal Distance to Floor: 22.6 inches (57.5 cm)                Mobile Unit        Weight: 1210 pounds (550 kg)        Size (L x W x H) 53.35 inches x 26.7 inches x 77.6 inches (1355 mm x 678 mm x 1970 mm)        Touch Screen Console: 17" inch monitor        Anti-collision System : Yes, Frontal and Lateral        Motorized Unit: Yes, 4 km/h        Motor Drive(Standard): Two (2) independent drive motors, one for each wheel (forward and reverse)        Battery Systems: Two (2) independent systems for drive and exposure
NEWSView All
Canon U.S.A. and Virtual Imaging Showcase New Product and...
“Since launching the world’s first digital radiography system, the CXDI-11 detector, in 1997, Canon Inc. has been dedicated to providing radiologists with the technology they need to meet the demands of the industry,”
