Medison - Accuvix A30
by Medison
Samsungs Accuvix A30 Ultrasound System establishes a benchmark for imaging.
Offering features such as the proprietary EZ Exam and ElastoScan, this system facilitates clinical decision-making and boosts diagnostic confidence. Its 21.5-inch large screen LED monitor combines with enriched 3D performance to deliver uncompromising image quality for increased detection rates. Its customisable interface and progressive ergonomic design provide flexibility and ease of use. This is complemented by advanced automation and imaging tools which transform separate exams into a single streamlined procedure for faster, more relevant results.
FORUMSView All (4)
-Basiloua
5 months ago
Problème de demmarage
Bonjour mon accuvix ne démarre plus lorsque j'actionne sur on je n'ai rien a ecran
Equipment: Accuvix A35
Hello my accuvix no longer starts when I press on I have nothing on the screen
-HENG
2 years ago
Admin password?
Need to change language, any help would be great :)
-welispolisystem_7585
4 years ago
accuvix a30lv
boa tarde., alguém pode me ajudar.,preciso do instalador da accuvix a30lvReply
[u]Hybrid Beamforming Engine[/u]
  • The Hybrid Beamforming Engine, with its enhanced hardware and software, enables more indepth and detailed scanning. The result of this is improved color performance. Hybrid Beamforming, also known as spatial filtering, offers greater flexibility than standard omnidirectional reception and transmission. The key benefit is its ability to adapt its response to different situations, which leads to optimized processing. Data can therefore be analyzed and processed more rapidly and accurately leading to more timely and confident diagnosis.
[u]21.5-inch Full HD LED Monitor[/u]
  • The Accuvix A30 comes with 21.5-inch ultrasound monitor for sharper, easier-to-view images. By adapting the advantages of Cathode Ray Tube (CRT) and Liquid Crystal Display (LCD) the widescreen monitor displays high contrast and superior resolution. The wider monitor, with its enhanced color delivery, presents a significant improvement in performance over traditional black and white screen technology. The uncompromising image quality supports informed clinical decision making and leads to increased diagnostic confidence while saving both time and effort.
[u]EZ Exam[/u]
  • EZ Exam transforms frequently used step-by-step exams into one single, streamlined procedure to offer enhanced usability. The ability to rapidly flip from one function to another has a significant impact on time and efficiency. Furthermore, it reduces the possibility of errors arising from fragmented data collation.
[u]Enhanced DPDI[/u]
  • Accuvix A30 with its enhanced Directional Power Doppler Imaging (DPDI) detects peripheral blood vessels. Its advanced and ultra-sensitive color Doppler enables more accurate diagnosis than its standard counterpart, including in circumstances where color detection is particularly difficult. DPDI complements other features of the Accuvix A30 to deliver more reliable diagnosis.
[u]Dynamic MR plus[/u]
  • Samsung’s powerful software has been integrated into a better engine to offer superior image quality. DMR plus is a noise reduction filter that increases edge enhancement to produce sharper 2D images. The resulting refinement in image quality delivers increased accuracy and confidence in diagnostic practice.
[u]Color Opt Flow[/u]
  •  Samsung’s Color Opt Flow enables color and power imaging of blood flow and is compatible with Doppler sensitivity settings. Upgraded capabilities include the ability to select and control slow, moderate or fast color settings. The preset ranges are designed to deliver more rapid evaluation of optimized blood flow images where required. This Samsung-exclusive tool also increases efficiency by reducing the amount of manual manipulation needed.
[u]HD ADVR[/u]
  • HD ADVR, integrated DVD (720 x 480) and USB (Full HD 1920 x 1080), permits simultaneous scanning and recording, creating an environment that allows users to revisit recorded areas.
Cart Based1
Portable1
Monitor (inch): 21.5 Wide LED    Tilt/Rotate Adjustable Monitor: Yes    Monitor Resolution: 1920 x 1080    Touch Screen (Inch): 9"    Trackball or Trackpad: Trackball    CP Back-Lighting: No    Probe Ports: 4    Battery: No    Maximum Depth of Field: 30cm    Minimum Depth of Field: 2cm
