Stahl Endoscopy - LED 300
by Stahl Endoscopy
The Stahl LED300 light source is a compact, efficient, durable source of brilliant “daylight” quality light for almost all endoscopy applications. The lumen output is comparable to many Xenon units, but is more stable and efficient. The expected LED life of 30,000 hours eliminates costly periodic lamp changes. The temperature color is 6950º K nominal with virtually no UV or IR emissions. It has a turret with multiple connectors: Acmi, Olympus, Storz and Wolf, so you can keep using your existing light cable.
[list] [*]Compact, efficient, durable source of brilliant "daylight" quality light for endoscopy. [*]Lumen output comparable to many 300 watts Xenon Light sources but more stable and efficient. [*]Expected LED life of 30,000 hours (15 years @ 40hrs/week x 50 weeks/year) eliminates costly periodic lamp changes. [*]Color temperature 6950°K nominal from 0-100%. [*]High-level command interface facilitates remote control and status access through integral RS232 and USB ports. [*]Ergonomically designed turret includes ACMI, olympus, Storz and WOlf ports; single port version and other port styles are also available. [*]LED automatically shuts off LED but keeps light source energized and adjustable. [/list]
Height | 4.5 in |
Length | 11 in |
Weight | 7.5 lbs |
Width | 11 in |
Power: Accepts 100-240V AC, 50/60 Hz input power for worldwide operation. Regulatory: EN60601-1 3rd edition, CAN/CSA C22.0 No. 601.1, mark.
