Wallach - WA1000B
High performance features and professional appearance make the WA1000B™ your best choice.The WA1000B™ console offers the ideal combination of easy-to-use controls and built in safety features. It uses the powerful LL100™ two-trigger freezer for Nitrous Oxide. (Carbon Dioxide units are designed differently due to the properties of the gas.) Freeze and defrost only occur when triggered and can be stopped instantly. A console-mounted switch must be activitated to permit gas to flow into the LL100™ and a color-coded gauge provides gas pressure reading at a glance. The Temperature Indicator gives surgeons unparalleled control and efficiency during cryosurgery. A large selection of reusable sterilizable cryotips and disposable plastic shields are available.
[list] [*]All the advantages of the LL100™ Freezer. [*]Precise read-out of tip temperature on thermocoupled tips. [*]Audible freeze timer starts when freezing temperature is reached and displays total time the tip is actually freezing. [/list]
