Wallach - LLCO2
by Wallach
The LLCO2 single-trigger cryosurgical system maximizes temperature and minimizes the clogging and sputtering commonly associated with CO2 gas. The Wallach LLCO2 CO2 Cryosurgery System is designed to handle the challenges posed by carbon dioxide, which is a gas, liquid, and solid in a narrow temperature range. The LLCO2 Cryosurgical System features a single trigger design that maximizes temperature and minimizes clogging and sputtering commonly associated with use of CO2 gas during cryosurgery. Freeze and defrost only occur when triggered (trigger to freeze, release to defrost). The LLCO2 is the ideal system to use with CO2 when N2O is not practical or available. The LLCO2 is light weight, well-balanced and maneuverable, providing full view of the target tissue. The Carbon Dioxide Cryosurgical Freezer's gas hose allows for unimpeded surgical movement.
[list] [*]Trigger to freeze, release to defrost [*]Use with medical grade CO2 gas for optimal performance [*]Lightweight, well-balanced and maneuverable [*]Use with Wallach’s standard cryotips with disposable plastic shields [/list]
| Weight | 5 lbs |
Handle length:5.89 in (15 cm) Operating pressure:650 to 800 psi Operating temperature:-65 degrees Celsius (-149 degrees Fahrenheit) Shaft length:5.88 in (14.9 cm) Tubing length:5.5 ft (1.68 m) Tip sterilization:Prevacuum or gravity, 135 degrees Celsius (275 degrees Fahrenheit) Cycle time:10 min with drying time of 10 min
