Draeger - Primus
Step up to the high standard of anaesthesia workstations and experience new levels of performance, efficiency and safety.FORUMSView All (6)
2Replies16 days ago | Fan Fail Error Drager Primus After self test is done a low priority error show up: " Fan for perventing internal oxygen build-up Fail " Anyone know where that fan is located? and to repiar the fault. Thanks Equipment: Draeger - Primus Reply |
0Replies2 years ago | com1 fail, what's reason? com1 fail, what's reason? Equipment: Draeger - Primus Reply |
0Replies2 years ago | anesthesia PGM parts and function Equipment: drager primus Reply |
[list] [*] Personal anaesthesia assistant - The Dräger Primus was designed to be nothing less than your personal anaesthesia assistant. It’s a combination of time-tested design and state-of-the-art technology created to answer the demand for a modern, comprehensive anaesthesia solution for today’s increasingly complex healthcare environment. [*] Common operating philosophy - The Primus® uses the familiar user interface and operating philosophy common to all current Dräger medical devices. This means that in spite of its impressive level of sophistication, your staff will spend a minimum amount of time learning how to use the Primus. [*] Enhanced workflow - Features like fully automatic self-check, open architecture, standard user interfaces and flexible monitoring options were designed to help reduce costs, save time and allow caregivers to focus on their primary task – the patient. [*] ICU standard ventilation - An increasing percentage of critically ill patients in the operating room calls for new standards in anaesthesia platforms. With the E-Vent® plus high-speed electronic piston ventilator, the Primus® delivers just that – peak flow comparable to ICU ventilators while avoiding the need for drive gas. A full range of volume and pressure oriented modes provides the various options for every clinical situation. Additional advanced monitoring and ventilation mode packages are also available that will expand your capabilities. [*] Comprehensive monitoring - The Dräger Primus?® lets you monitor pulmonary function and ventilation parameters on a large, user-configurable 12,1“TFT colour display. Its open architecture design provides the option to add additional displays, permitting you to expand your monitoring capability to include haemodynamic and other data. [/list]
Vaporizers (Max) | Two |
