Fujifilm - FCR XG1
by Fujifilm
Fujifilm’s FCR XG-1 Computed Radiography system greatly simplifies digital X-ray imaging. This extremely compact device reads and processes digital X-ray image information that’s been recorded on an imaging plate (IP) using a cassette-type X-ray stand. Simple by adding the XG-1 to your existing equipment, your radiography room can provide all the benefits of a highly advanced digital system, without having to replace all of your equipment. Portability and connectivity features ensure unprecedented versatility, since you can move the imager outside the radiology department, establish a remote imaging network, then quickly and easily print out hard copies on film using an image recorder. FCR XG-1: the digital X-ray imaging system that’s easy-to-use and goes anywhere.
2RepliesSat Jun 28 2025 | Error Any one help me my xg-1 CR got error 10343 Equipment: Fujifilm - FCR XG1 Reply |
2RepliesFri Jun 20 2025 | Error 10391
Equipment: Fcr XG_1 Reply |
1ReplySat Apr 26 2025 | error 10318 On power up the suction motor only drives the cups forward, does not go to home position any recommendations? Equipment: fuji xg1 Reply |
[list] [*] Advanced digital-image processing produces easy-to-read, high-diagnostic-value radiographs. [*] Can use the XG-1 in a multitude of environments and situations. [*] The XG-1 works with most existing equipment, ensuring that you reap the benefits of digital without having to replace your radiography room equipment. [*] In multiple-unit configuration, CR Console will mutually share the patient's database throughout the network allowing easy access to the patient datasets from anywhere. [*] Compact single-cassette reader with automatic feed/load streamlines workflow, improving cost performance with processing potential of 62 IP/hr (14" x 14"). [*] Wide dynamic range captures rich diagnostic information; automatic sensitivity-adjustment function minimizes variations in X-ray exposure, ensuring more consistent image quality. [/list]
| Height | 41.9 in |
| Length | 21.7 in |
| Weight | 342 lbs |
| Width | 20.3 in |
Reading Gray Scale: 12 bits/pixel Power Supply: Single phase 50-60HZ, 120/200-240VAC ±10%, 2.6-1.3A Environmental Conditions Temperature: 15~30°C Operative Conditions Humidity: 40~80%RH (No dew condensation)
