Visaris Americas - Visaris360
by Visaris Americas
The Heart Of Your Digital Radiology
Visaris360 incorporating an efficient, scalable digital PACS archive, powerful and ergonomic diagnostic radiology workstations and a streamlined and efficient radiology workflow system (RIS) is an integrated suite of radiology workflow tools covering the complete diagnostic process from exam planning and scheduling to diagnostic finding distribution. Offering a high level of automation and seamless integration of all steps and people in the diagnostic process, Visaris 360 will expedite and give you control over your workflow.
SERVICE COMPANIESView All DR Systems Companies
VisarisPACS – Your Well Deserved Peace of Mind
  • VisarisPACS is a DICOM compliant digital medical imaging archive that provides all digital archiving and communication functionality for a modern, truly digital radiology department. Powerful patient search lets you locate and access data in the archive in a matter of seconds. Retrieve images from a range of imaging modalities using latest communication protocols and display them to perform screen based diagnostics.
  • Digital DICOM Archive with fully scalable storage and client access
  • Integrated DICOM communications: Store, Query, Retrieve, Search
  • Transfer scheduled exams to modalities directly with DICOM MWL service
  • Store images reliability with DICOM storage commitment
  • Access your patient/exam/image database quickly
  • Use your resources efficiently with image and automatic storage compression
  • Know the status of each exam with integrated DICOM MPPS service
  • Import years of existing images with a few clicks
  • Manage your PACS easily with powerful admin and service modules
  • Manage storage space, users, DICOM connections, patient data …
  • Never lose your data with automated backup
Do More With Visaris Diagon Workstation
  • Perform your diagnostic reading with Visaris Diagon radiology workstation software that seamlessly integrates within any DICOM compliant radiology network. Base it on the hardware of your choice to retrieve your patient data with ease, apply powerful processing and turn your findings into great looking reports with Diagon, active diagnostic workstation:
  • Multiple high resolution display support (up to 3 monitors and up to 5MP)
  • Advanced PACS query/retrieve supporting wide range of modalities
  • Retrieve previous studies automatically and display them side by side
  • 2D still and multi-frame display, processing and manipulation
  • 3D imaging display and processing:MIP, MPR, VRT, MinIP, SSD
  • Process time-frame sequences: frame extraction,replay, loop, pause, advance
  • Measure, annotate and analyze using a wide range of analytics tools
  • Receive images from modalities directly to your Diagon workstation
  • Import non-DICOM images and re-format as DICOM
  • Dictate or type your reports on custom structured report (SR) templates
  • Export images or burn them to CD with embedded DICOM viewer
  • Roaming profile, service and configuration module
Expedite Your Workflow and Disseminate Your Findings Easily
  • Visaris RIS is a fully fledged, highly automated Radiology Information System that provides efficient electronic support diagnostic radiology workflow. Boasting a high level of automation and powerful analytical tools, Visaris RIS will expedite the diagnostic process and give you a level of control over your work you could not experience in conventional radiology departments. Based on a web (browser) platform, Visaris RIS is easily scalable to help your findings reach those they are intended to quickly and easily.
  • Completely manage diagnostic workflow
  • Enroll patients, create and schedule exams on all your devices
  • Plan, monitor and direct exam progress– in real time
  • Access and export results in a variety of forms
  • Transcribe and verify reports so you can focus on the important
  • Access images and findings from anywhere in the network
  • PACS preview: quick non-diagnostic image display and manipulation
  • Remain in control of you material usage and stock levels
  • Integrate a CD burning robot for professional looking results
  • Integrate easily with existing billing systems
