Tuttnauer - 3850M
by Tuttnauer
Tuttnauer 3850M Tabletop Manual Autoclave
The Tuttnauer® Model 3850M autoclave is designed for sterilizing laboratory and medical equipment, media and even liquids. The Tuttnauer® autoclave provides fast, safe and dependable sterilization without any need for special plumbing or venting. Tuttnauer® autoclaves are manufactured with 316L stainless steel sterilization chambers which are highly corrosion-resistant. These autoclaves feature a fast exhaust option which reduces cycle time for solid goods and a slow exhaust option which releases chamber pressure slowly and prevents boiling over of liquids. Cold air pockets are eliminated by continuous pressure purging which ensures uniform sterilization.
The autoclave includes a 3.25L water reservoir which allows complete control the purity of the sterilizing steam and allows repeated use without the need to refill very often. The integral drying cycle prevents corrosion of expensive instruments and also dries absorbent materials. The autoclave also includes a low water level alarm which prevents damage to the heating elements. Tuttnauer® autoclaves feature a double-locking door that is insulated for high heat and protects lab personnel from accidental burns. The door cannot be opened when chamber is pressurized by means of a dead-bolt mechanism for added safety.
Tuttnauer® Model 3850M autoclave is an economical, mechanical autoclave with analog controls and analog temperature and pressure. Furnished complete with a 60-minute timer and temperature level control from 100 to 134°C (212 to 273°F). Diameter x Depth: 15 x 20-Inch. Capacity: 65-Liters. Includes support stand and two removable and adjustable stainless steel tray shelves to accommodate varying sizes and heights of laboratory instrumentation, glassware and vessels. Electrical: 220V/2400W.
  • Analog control with analog display of temperature & pressure. Heating time to 273°F (134 °C): 30-Minutes
  • Heat-insulated, double-locking door protects against accidental burns. Door cannot be opened while chamber is under pressure.
  • Automatic low water level shut-off prevents damage to heating elements when there is insufficient water for the sterilization cycle. UL Listed, CSA Certified & ASME Stamped.
Chamber Volume65 L
Chamber Width15 in
Height26 in
Length 26 in
OrientationBenchtop
Power Requirements230 VAC
Weight140 lbs
Chamber Depth20 in
Width20 in
