Lumenis - LightSheer DESIRE
by Lumenis
Lumenis, a leader in laser and energy based technologies, developed the LightSheer DESIRE, the new generation of Laser Hair Reduction system from the LightSheer Family of products, so you can grow your business by offering your patients what they DESIRE.
1ReplyFri Jan 10 2025 | Service Manual Does anyone have a service manual for the Lumenis Desire Equipment: Lumenis Desire Reply |
0RepliesThu May 16 2024 | Service manual Hi, do you have lumenis desire service manual Equipment: Lumenis desire Reply |
4RepliesTue Oct 26 2021 | The device gives an error E82 E84 Good afternoon. The device gives an error E82 and E84 when changing attachments. If the device is loaded with the attached attachment, then only the ET manipulator works without errors. Recently, the power supply was repaired (the diode exploded and 2 power keys were punched, respectively, the fuse), after repair it worked normally for two weeks. What could be the cause of the malfunction? Thank you for the attention)Reply |
[list] [*] Satisfied Patients - Treatments are cost effective and large areas can be treated in less than 10 minutes, so you can see more satisfied patients. [*] Faster Learning Curve - The system is simple to operate and has a friendly Graphic User Interface (GUI) and preset programs- For a faster learning curve and easy treatment delegation. [*] Treatment Versatility - The handpieces have been ergonomically designed and can be switched using a simple 'Plug and Play' method-To allow versatility in treatment options and improved system handling. [*] Multi-Location-Usage - The system is light and portable and can easily be transported from one place to another- To enable multi-location use. [*] Upgrade - The system is up-gradable so it can grow with your business-To fit your needs in any given time and match your practice requirements so you can maximize revenues. [*] Desirable Clinical Results - The LightSheer technology by Lumenis has been validated in numerous clinical studies and peer reviewed articles. Thousands of satisfied customers have been and are still benefiting from the gold standard performance and patient satisfaction. [*] Faster Treatment - High-Speed Integrated Technology (HIT™) reduces treatment time by more than 75%. Using the 22x35mm spot size, large areas as the back and legs can be treated in less than 10 minutes. THE HIT ™ eliminates the lengthy preparation time need need for cooling or anesthetics. [*] Ultimate Patient Comfort - High-Speed Integrated Technology (HIT™) uses a unique vacuum mechanism that activates the skin's tactile and pressure receptors to inhibit the transmission of pain. ChillTip™ Technology improves patient comfort by cooling the skin prior to treatment and continuously cooling it throughout the treatment. [*] Clinically Validated Efficacy - Numerous clinical studies and peer review articles have validated the safety and efficacy of the technologies powering the LightSheer DESIRE. Thousands of satisfied customers have been and are still benefiting from the gold standard performance and patient satisfaction. [/list]
| Laser Type | Diode |
| Height | 42 cm |
| Length | 60 cm |
| Weight | 32 kg |
| Wavelength | 805 nm |
| Width | 51 cm |
