Rigel Medical - VenTest 800
by Rigel Medical
Measuring your pneumatic equipment for reliability and precision with a dependable calibration tool is critical in avoiding fatal errors. Precision and reliability are exactly what the VenTest Series provides. The VenTest measures flow, pressure, temperature, humidity and O2 concentrations bi-directionally. The one-of-a-kind adult, pediatric and high-frequency ventilation measuring modes make the VenTest the ideal calibration tool for all ventilators, anesthesia machines and spirometers.
[list] [*] All-in-one analyzer - The all-in-one adult, pediatric and high-frequency ventilation measuring modes make the VenTest the ideal calibration tool for all ventilators, anesthesia machines and spirometers. [*] Measures and calculates all common respiratory parameters - Flow, volume, pressure, oxygen, temperature, humidity (measured) and Vti, Vte, Vi, Ve, Ti, Te, Ti/Ttotal, Ppeak, Pmean, I:E, PEEP, Rate, PF Insp., PF Exp., Cstat, Pplateau and Delta P (calculated). [*] Compatible with gas standards and gas types - Built-in compatibility for measuring ventilator performance in 13 gas standards and 10 gas types such as: Air, O2, N2O, He, N2, CO2 and Mixed: Air/O2, N2O/O2, He/O2. [*] Built-in data storage with optional software for total traceability - [*] The VenTest has an internal memory that allows you to store up to 10 records, each containing up to 16 measurement values, eliminating the risk of manual data capture error and the hassle of paperwork. [*] USB, RS-232 and external trigger interface - The VenTest communicates with your test software and ventilator to improve automation, increase traceability and standardize the process of testing ventilators. [*] Portable with battery operation - Up to 3 hours of battery life provides convenient and fast testing when you are on the go or without access to mains power Ventilator Analysis Test Functions [*]Bidirectional flow [*]High and low pressure [*]Differential and barometric pressure [*]Oxygen concentration [*]Temperature [*]Dew point [*]7 anesthetic gas concentrations (with OR703) [*]Respiratory parameters [/list]
| Analyzer/Simulator Type | Ventilator Test System |
Rigel has extended its range of test instrumentation for biomedical equipment with the introduction of a ventilator tester.
