Siemens - CA 620/660
by Siemens
Coagulation Analyzer
The Sysmex CA-600 Systems are compact, fully automated systems featuring clotting, chromogenic, and immunologic* measurements in true random-access.
-StaceyP
Wed Jul 22 2020
Need User Experience
Our laboratory is looking to purchase a coagulation analyser and was recommended this model however we would like user feedback on its performance before deciding on the purchase. Thank you in advance.Reply
  • Automated probe rinse eliminates manual steps
  • Simultaneous analysis of results frees up time
  • Increase D-Dimer throughput by 40?
  • Hand-held two-dimensional barcode reader simplifies the data entry process for ISI, control and calibrator values, lot numbers, and expiry information
  • Sample barcode reader provides simplified sample ID processing and enables security and integrity of patient records
  • 25% less power consumption
  • Minimal consumables needed—only CA Clean I, CA Clean II, and reaction tubes
  • Only one reaction tube used per test
  • Results correlate with the entire line of Siemens hemostasis systems
  • Provides confidence through standardized results
  • Hand-held 2-D bar-code reader automates the data entry process for calibrator and control values
  • Easy-to-use system handling with intuitive menu structure and tilted color touchscreen
  • STAT sample processing enables critical tests to be processed at any time
  • Analyzed data may be displayed or printed with reaction curves for flexibility in result management
  • Environmentally friendly system with minimized reaction tube waste
  • Menu includes the most frequently requested routine and specialty tests, including INNOVANCE D-Dimer
Height19.5 in
Length 19.5 in
Weight94.6 lbs
Width22.5 in
