STERIS - QDJ04
by STERIS
 Dual Chamber blanket/fluid warmer
AMSCO / Steris Dual Chamber Blanket/Fluid Warmer, Dual Independent Digital Temperature Control, Freestanding With Stainless Steel Side Panels, Two Adjustable Shelves, Stainless Steel Or Glass Door
FORUMSView All (15)
-denver
Thu Nov 07 2024
UNIT NOT WARMING
top part of the unit working good. issue with the bottom unit fan wasn't not work so I replace it and still temp unit is not warming up
-Jhorcher
Thu Jan 11 2024
Temprature setting flashes and will not reach proper temp setting
Having trouble setting the temprature on the lower warmer.
Equipment: STERIS - QDJ04
-ZachB
Thu Dec 28 2023
Erratic Display
Has anybody had a problem with a fluctuating temp on both displays?
  • stainless steel construction
  • LCD temperature windows for upper and lower chambers
  • overtemp indicators for each chamber
  • two shelves in lower chamber; both chambers accept shelf brackets
Height75.5 in
Length 28 in
Weight300 lbs
Width30 in
  • Inner dimensions of the upper compartment: width : 23.5 in.   depth: 22   height: 13
  • Inner dimensions of the bottom compartment:width: 23.5 in.   depth: 22   height: 38
