Fluke Biomedical - QA-ES III
by Fluke Biomedical
The QA-ES III Electrosurgical Analyzer is the ultimate solution for biomedical engineers and clinical HTM professionals who require accurate, efficient, and comprehensive testing of electrosurgical units (ESUs). Engineered to test all modern high-frequency electrosurgical generators, the QA-ES III ensures both performance validation and electrical safety compliance with unmatched ease. (Generated by AI)
0RepliesSat Jun 23 2018 | QA-ES III - What's in the box Collect all measurements including vessel sealing, contact quality monitor (CQM), high frequency (HF) leakage and output power distribution in single or continuous mode. Reply |
0RepliesSat Jun 23 2018 | QA ES III - Generator Output Test Power distribution: Tests impedance-sensing circuitry in power guarantee functions in new-generation ESU. Applicable parameters power, current, peak-to-peak voltage (closed load only) and crest factor can easily be observed during the automatic, sequential output energy measurements.Reply |
0RepliesSat Jun 23 2018 | QA-ES III - Power Distribution Test QA-ES III - Power Distribution TestReply |
High-Precision Output Measurements: Delivers generator output current accuracy down to ±2.5%, ideal for testing high-power ESUs used in today’s surgical procedures.
Complete ESU Testing in One Device: Measure vessel sealing, contact quality monitoring (CQM), HF leakage currents, and output power distribution—all in single or continuous mode—without additional equipment or cables.
All-in-One Compact Design: No external accessories needed. This portable analyzer includes all necessary hardware and software, reducing your setup time and streamlining workflow in the field or lab.
Wireless Functionality*: Supports wireless data capture and control, enhancing mobility and eliminating cable clutter in busy clinical environments.
Ansur Automation Software Integration: Compatible with Ansur test automation software, enabling custom test templates, automated procedures, real-time data capture, and professional-grade reporting—perfect for compliance documentation and quality assurance. (Generated by AI)
| Height | 14.5 cm |
| Length | 47 cm |
| Power Requirements | 100 VAC |
| Weight | 7.5 kg |
| Analyzer/Simulator Type | ESU |
| Current Range | 0 to 5500 mAh |
| Width | 35 cm |
