Hillrom - Micro Lite PhotoTherapy System
Hill Rom Air Shields Micro Lite PhotoTherapy SystemThe Hill-Rom Micro-Lite Phototherapy Unit is a compact unit housing three 50W halogen bulbs and a fan. The fan runs while the lamps are lit and continues for a further three minutes after the unit has been switched off. The Micro-Lite may be placed on an incubator canopy. A mobile stand is also available which allows vertical and tilt movement of the lamp once it is safely secured to the stand. The unit displays an LCD timer which can be reset between patients.
1Reply6 years ago | Product Manual To whom it may concern: Our facility received this phototherapy light from our larger, sister facility but we did not receive a manual. Are we able to order one from your company? The documents/manuals tab will only display a brochure, not the actual users manual we are needing. Thank you for your assistance, Norma Ginger, RNReply |
0Replies8 years ago | Micro-Lite Model PTS68-1 Trips Breaker Thank you for helping us with the Hill-Rom/Airshields/Drager Micro-Lite unit. I have two units that keeps tripping breaker. I have isolated problem to the main power board. The board shows where unit got hot, but resistor tests fine. As soon as you try to plug into power supply board, then circuit breaker trips. I do not have service manual to help troubleshoot or to find part numbers for ordering replacement parts. Thanks for any help you can provide. Reply |
[list] [*]3 x 50W halogen bulbs [*]Treatment timer [*]Lamp life timer [*]Wide waveband [*]Fan to cool bulbs [*]Stands on incubator canopy [/list]
