BD - BD Accuri C6 Plus
by BD
Flow cytometer
The BD Accuri™ C6 Plus offers simplified workflows and ready-to-use templates for performing a wide range of applications in flow cytometry. When combined with the portfolio of BD reagents and best-in-class service and support, it is an ideal solution for life science researchers performing routine assays in cellular analysis, while also reducing operating costs. This new generation platform has several optimized enhancements to the internal hardware, fluidics, and software while maintaining the core elements of the prior platform such as the unique, non-pressurized, peristaltic pump system and compact exterior design. The ability to use BD CS&T RUO beads helps users with simplified QC methods, improving reliability of the experimental data.
  • Highly sensitive: MESF <75 (FITC) and <50 (PE)1
  • Non-pressurized peristaltic pump system
  • Event rates up to 10,000 events per second
  • Supports sample collection from multiple sources, including
  • Uses laboratory-grade water as sheath fluid
  • Easy-to-Use Software with Automated QC and Application Templates
  • Immunophenotyping and Cytokine Analysis
  • Rapid Analysis of Multiple Cellular Processes
  • Characterizing Stem Cells and Their Derivatives
  • Microbial Analysis Across a Range of Applications
  • Advanced Capabilities Expand Detection and Flexibility
Height11 in
Length 16.5 in
Weight30 lbs
Width14.75 in
  • Sample Tubes:12 x 75-mm (or smaller)
  • Decade Dynamic Range: 7.2 (16 million channels of digital data)
